I have a very old computer and have to replace all parts. Going to get a major upgrade soon but I want to get everything early.
My build is here http://pcpartpicker.com/p/xHKNjX
Here is my problem I want to get everything early and the only way to do that is to get everything other than the graphics card. What I want to know will the i7 4790k do good or at least playable on games. The kind of games... Stranded Deep, Grand Theft Auto V (not expecting much), and some other games that are not like AAA titles. It will take maybe three weeks to get everything else sol is this a good idea?
Update: I am also using this for video editing.
https://linustechtips.com/topic/352109-need-help/
Oh my god that is unbalanced. get a R9 270 at least for adequate gaming if you're going to spend 900-ish dollars on an upgrade, or that card will not give you a fun time.
If you're using a H-series board, you won't be able to OC that K-processor. So upgrade the board, or get a non-K processor to save up some dough (preferably for the GPU)
Video editing may require more than 8 GB of ram, so be careful there, someone else will have to back me up on the RAM situation
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/352109-need-help/#findComment-4787382
Here, much better. It even has some spare money to get a better case, if you want.
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.95 @ SuperBiiz)
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($49.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0 Video Card  ($315.04 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.79 @ OutletPC)
Total: $847.71
Generated by PCPartPicker 2015-04-20 23:28 EDT-0400
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/352109-need-help/#findComment-4787403
