Help pick me a case
Here is a pic of my PC + Specs!
What I need: 240mm rad space, 3 hdd, 1 ssd (back mounted preferably), couple of fans, dont worry for dvd drives I can use that space for fans or rads. Black and clean case with good wiring holes.
I want to buy a Define S but I cannot find it in any australian retailer :(!!!
If anyone finds this case in Australia PLEASE contact me asap.
Comfortable with $150 but can go higher
https://linustechtips.com/topic/351813-help-pick-me-a-case/
Was going to reply to this *Sees that you didn't include your budget* *Leaves*
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/351813-help-pick-me-a-case/#findComment-4783190
NZXT S340 amigo if your on more of a budget, should fit all that
Otherwise I would recommend the R5 of course :P
Maybe the node 304 if your feeling adventurous :)
Just watched linus' video on the NZXT it looks good, I think I will get it if I can't find the S.
https://linustechtips.com/topic/351813-help-pick-me-a-case/#findComment-4783254
