Hi I have been on a really well recommended and accurate power supply power generator to figure out what wattage of power supply i will need for my pc it says 484 watts and the power supply i have is 520, do you think this is fine? if not could you please recommend other silent power supplies. and also if it isn't enough what do you think about corsairs RM power supply series.
Thank you very much.
https://linustechtips.com/topic/351351-power-supply/
I would recommend going with much higher than 520w, you want to have around 100w extra when maxed out.
https://linustechtips.com/topic/351351-power-supply/#findComment-4777167
It would help to list your specs.
https://linustechtips.com/topic/351351-power-supply/#findComment-4777213
520 x 80% = 416  your psu  whopping around 80 - 100 % so I recommended to get a new one you need at least 650w
That's not how efficiency works. A 520w psu should be able to output 520w regardless of efficiency. A less efficient psu will just draw more power from the wall to supply the wattage.
https://linustechtips.com/topic/351351-power-supply/#findComment-4779274
Your current PSU is fine I think
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/351351-power-supply/#findComment-4780157
I have an intel core i7 4930k with 2133mhz 16gb corsair dominator platinum memory an asus z97 deluxe mobo and a gt 970, the psu is a seasonic fanless 520 watt psu.
You're fine.
https://linustechtips.com/topic/351351-power-supply/#findComment-4782043
You're perfectly fine. The Seasonic fanless are better then the Corsair RM
"Rawr XD"
https://linustechtips.com/topic/351351-power-supply/#findComment-4782896
