TVs are terrible with text. NVIDIA GPUs also don't compensate for TV overscan. Can you tell if you desktop is slightly extending off the screen? Perhaps maximize a window and see if the edges are getting cut off?
https://linustechtips.com/topic/351337-quality-issues/#findComment-4777153
the edges were getting cut off, but i resized it. I had this problem with my last screen but dont remeber how i fixed it.
Resizing from the computer's end uses interpolation algorithms which is probably what's causing the main problem here. You need to go into the actual TV's menu and adjust scan settings, change it to "just scan" or "1:1" and then undo the resizing from the computer.
https://linustechtips.com/topic/351337-quality-issues/#findComment-4777202
