Need a block for my GTX Titan, but i have looked for a reasonable one and have not found one, very frustrated right now, If you guys know Of anyone who sells A water block for a GTX Titan, It would be much appreciated if you link me. Thanks.
:ph34r:
Next Time post it in the Watercooling thread;) http://linustechtips.com/main/forum/36-water-cooling/
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/351086-water-cooling/#findComment-4774335
