So its possible my motherboard has some parts fried on it. I have RMA'd my GPU three times and none of them have worked. I don't have another motherboard or another GPU so I almost need to buy motherboard to see if it is in fact my motherboard that's bad. However it says on Newegg that they may charge a 15% restocking fee. Will they, I don't want to buy a motherboard, have it still not work and have to pay shipping and a restocking fee. HELP!
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/350622-possible-motherboard-problems/
Random question, is this the board you painted in your build log?
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
Yes, I only painted the heatsyncs but yes it also voids the warranty.
| F@H STATS |
I asked because I sprayed board once and had an issue because a single PCI pin got a speck of over spray on it... Have a look
Its very strange that you have had 3 GPU's not working, what was the symptoms?
No paint got near the PCI slots and I've tried all the slots. The GPU works great, reads 100% of all the specs in GPUz and can do some light loads like 4k video but when I put it under a big load like most games or stress tests the fans go to 100% and my computer reboots.
| F@H STATS |
That Fault to me smells of power issue, Have you tried a different PSU? Did you try different PCI cable from the nice braided one?
No, I did RMA the PSU and that was right before I got my seconded GPU and the seconded and third GPU did the same thing however I can stress test my CPU and it works just fine. Should I maybe check where they plug into the PSU.
| F@H STATS |
Did you only ever try the braided cables?
Yeah but I imagine its somewhere else. I'll look when o get my RAM back.
| F@H STATS |
Wow looks like you have been having a right nightmare, good luck and hope it all works out in the end...
The only reason I RMA'd the PSU is because it had bad coil whine.
| F@H STATS |
