Need help with upgrading friend's pc
Go to solution Solved by Oseth,
His GFX is definitely what's holding him back the most. I would get a nice newer GFX or two (I prefer single units) and see what it does with his game, that way even if its still not good enough and you end up building a new rig you can still use the GFX card(s) in it. Otherwise, maybe double the RAM, 8gb is usually enough but I feel more comfortable with 16gb.
Keep in mind this is my opinion, some might disagree with it and that's fine.
Hello I'm currently trying to figure out what to do with a friend's pc... He wants to be able to run games better than he is right now and he recently bought GTA V and he can't play it at 60 fps with his current specs...
They are as follows:
CPU: I5 3470 @ 3.2GHz
Ram: 8GB DDR3 @ 823 Mhz
Motherboard: ASUSTeK COMPUTER INC. P8H61 R2.0
Graphics Card: ATI AMD Radeon HD 6670 2GB
Extra notes: He has a 1360x768 monitor right now but he's gonna jump to 1080p soon, so keep that in mind.
So yes, it is a prebuilt system.. But I just wanna know what's the best option here:
-Save up 500€ and build himself a decent rig which will meet his needs
-Just buy a graphics card like the R9 Radeon 260X or something a bit better to fit his current needs and postpone an entire system upgrade...
If the first choice seems more adequate i'd like a build ideas if possible... Thank you (:
https://linustechtips.com/topic/350143-need-help-with-upgrading-friends-pc/
EDIT: I thought it was a 290x... Well, I think a 280x should do the job, a 260x? Naaaa
Lets all ripperoni in pepperoni
Hmmm... I'm checking out the prices but... I'm a bit confused! xD
I see for example the 280x by Asus and by Sapphire, they seem to be same name but I'm sure they're different... What does all of this different branding influence? What's the best choice? :S
