is there's no problem to install r9 285 dual-x (uefi) card on s2p-78lmt ? performance or anything else ?!
because i just installed the r9 285 on my s2p-78lmt rev5 mobo and the monitor doesnt show any data ! and when i switch back to the onboard vga it works fine but with the onboard gpu for sure ..
https://linustechtips.com/topic/350020-help/
did you plug in the power for the GPU
https://linustechtips.com/topic/350020-help/#findComment-4761995
