Quadcopter, scrapyard wars like build to show that PC gaming can be cheap AF
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/349987-school-project/#findComment-4761462
get an arduino and mess around with that. You can do some really cool stuff with them
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/349987-school-project/#findComment-4761472
maybe an old raspi model A would come cheaper
I'm thinking of a low range radio transmitter.
What do you guys think?
https://linustechtips.com/topic/349987-school-project/#findComment-4761596
Would need to buy an arduino and the shield which will raise the cost too much :(
um no.....
no one should build a quad with something that uses 5v logic >.>
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/349987-school-project/#findComment-4761598
You should open a microwave and use the megnetometer to fry things
pls dont do this
https://linustechtips.com/topic/349987-school-project/#findComment-4761608
Why not? The only downside is that it's not a quadcopter...
Or maybe you could make a custom fan controller.
sudo chmod -R 000 /*
https://linustechtips.com/topic/349987-school-project/#findComment-4761685
Are you familiar with logic gates at all? Because if you are, i have some ideas of how they could be used in a project.
https://linustechtips.com/topic/349987-school-project/#findComment-4762716
Yeah i'm familiar with almost all logic gates. (Except X-NOR and X-OR).
We are doing several amazing stuff with them via MUX and DEMUX we are now learning about Encoders and Decoders.
https://linustechtips.com/topic/349987-school-project/#findComment-4764668
