I'm giving my CM Hyper 212 Evo to my GF for her Pentium-K and I'm in the market for a new cooler. I'm aiming at either a good air cooler or an AIO liquid cooler. I've taken a hard look at the Phanteks PH-TC14PE and the NZXT Kraken X61. But I'm not sure if AIO's do much better of a job over a good air cooler.
Based on my build seen in the attached photos, you'll see my overall look and RAM size, what would you guys suggest?
P.S. I'm running the stock cooler for now, and man, it is terrible. I can hardly run the CPU at stock speeds. Temps are hardly comfortable.
post-211843-0-40072500-1429236379_thumb.
post-211843-0-28237100-1429236544_thumb.
CPU: Intel i5-4690k                                                               RAM: 16gb Corsair Vengance Pro DDR3-2400        Case: NZXT S340
Cooler: CM Hyper 212 Evo                                                  Storage: Intel 730 SSD        PSU: EVGA 850G2
Mobo: Asus Z97-A 3.1                                                          GPU: 980ti G1        OS: Windows 10 Pro
https://linustechtips.com/topic/349585-4690k-cooling/
What kind of oc are you shooting for? If you're satisfied with your 212 Evo's performance, the Pure Rock performs slightly better while being much quieter: http://pcpartpicker.com/part/be-quiet-cpu-cooler-bk009
https://linustechtips.com/topic/349585-4690k-cooling/#findComment-4756563
I easily achieved a 4.4ghz @ 1.220v with comfortable temps with the CM Hyper 212 Evo... I wouldn't mind a bit more, around 4.6-4.8ghz.
https://linustechtips.com/topic/349585-4690k-cooling/#findComment-4756575
If you're doing it just for the clocks, here are some alternatives:
NH-u14s: http://pcpartpicker.com/part/noctua-cpu-cooler-nhu14s
PH-TC14PE: http://pcpartpicker.com/part/phanteks-cpu-cooler-phtc14pe
NH-D15: http://pcpartpicker.com/part/noctua-cpu-cooler-nhd15
Just a remind though: you'll probably be reaching the point of diminishing returns.
https://linustechtips.com/topic/349585-4690k-cooling/#findComment-4756609
If you wanna OC more, AIO I guess? Usually they will cool much better compared to air cooler.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/349585-4690k-cooling/#findComment-4756610
How's your Kraken X61?
https://linustechtips.com/topic/349585-4690k-cooling/#findComment-4756613
So far so good. Can't find anything I hate about it yet! The only "hate" was before they upgraded the software, now they have upgraded it, everything is really good.
https://linustechtips.com/topic/349585-4690k-cooling/#findComment-4756828
Just to add some more insight into what you can get the 4690K overclocked with AIO.
I'm running a 4.4Ghz Overclock @ 1.15v. With a coolermaster Nepton 240m AIO, which is by far not the best, but quite cheap for an AIO. Idles at 22 Degrees and hits 56 Degrees under load with XTU.
Sure I could go higher with the overclock but I don't really have any need to for what I use the rig for.
[CPU] i5-4690k 4.4Ghz @ 1.145v, [Cooler] CoolerMaster Nepton 240m, [Mobo] MSI Z-97 Gaming 5, [Memory] Corsair Vengeance Pro 16GB 1866Mhz,[storage] Samsung 840 Pro 250gb, WD 1TB Green, [GPU] EVGA 970GTX FTW Edition, [PSU] Corsair CX750M, [Case] Fractal Design Define R5, [Mouse] Roccat Kone XTD, [Microphone] Blue Yeti Black, [Keyboard] Corsair K-70
https://linustechtips.com/topic/349585-4690k-cooling/#findComment-4758155
im rocking the same speeds, hyper 212 evo, 60c highest core 3, folding temps the same.
https://linustechtips.com/topic/349585-4690k-cooling/#findComment-4758174
I probably should have listed this here, but I've actually decided to go with the Corsair H100i. I was about to pull the trigger on the NZXT Kraken X61, but that plastic backplate turned me away from it.
EDIT: Installed!
post-211843-0-94425700-1429309964_thumb.
https://linustechtips.com/topic/349585-4690k-cooling/#findComment-4759310
