Hello everyone. I just want to get your own feedback's on how is my very first build. These parts i picked were picked for gaming and editing videos as well. Here is a list of the parts i chose and used currently. Please note that the casing i used isn't the final build. I will be getting the cooler master Silencio 652S as my main Case. Feedback's and other ideas are welcome :) P.S If you have notice that my current casing doesn't have any front HDD and power led, I have move them to the side of my casing.
Lists of my PC Parts:
Motherboard: Asus Z97 Pro Gamer Motherboard
CPU: Intel Core i5 4460(Getting a 4690K in the future)
RAM: Crucial 12GB DDR3 1600MHZ(4GB By 3)
GPU: Asus Geforce GTX 750TI 2GB GDDR5
PSU: Cooler Master V650 650W Semi modular
Case(Currently): Cooler Master Centurion 534
Fans: Front: Corsair SP120 Back: Gigabyte 120MM Fan(From another case)
HDD: Seagate 250GB(Main, OS drive) and WD Caviar Blue 1TB(Steams games and etc.) and Seagate Slim backup drive 1TB(As backup drive)
ODD: HP DVD1270I
Hope to get ideas and feedback's from everyone :) And By the way, I also uploaded a picture of my dual monitor. :)
post-143851-0-70871300-1429233906_thumb.
post-143851-0-26098300-1429233917_thumb.
post-143851-0-00845000-1429233929_thumb.
post-143851-0-12967600-1429233939_thumb.
post-143851-0-91008500-1429233948_thumb.
post-143851-0-31058500-1429233957_thumb.
post-143851-0-26363200-1429233963_thumb.
post-143851-0-18259900-1429233974_thumb.
post-143851-0-88230000-1429233979_thumb.
post-143851-0-09987800-1429233987_thumb.
post-143851-0-80864700-1429233993_thumb.
post-143851-0-12430100-1429234004_thumb.
post-143851-0-31116800-1429234010_thumb.
post-143851-0-77166600-1429234017_thumb.
post-143851-0-93026600-1429234028_thumb.
If a leaf falls, Let it pick it up by itself and it will learn how to pick itself up with the wind
CPU: Core I5 4460 @ 3.2GHZ Cooler: Stock Cooler(future Upgrade to AIO Cooler) GPU: Asus Geforce GTX 750TI 2GB Mobo: Asus Z97 Pro Gamer Ram: 12GB Crucial DDR3 1600MHZ( 4GB By 3) Case: cooler master silencio 652s HDD: Seagate 240GB(Main) WD Caviar blue 1TB(Games etc.) Seagate slim backup drive 1TB(USB 3)
https://linustechtips.com/topic/349566-my-first-z97-build/
Install ram in pairs. 2 or 4 chips. Your build looks fine well done.
CPU: i7 4790k @ 4.4 GHz                                                 Case: Fractal Design Define R5                       SSD: Samsung Evo 850 250gb          Monitor:  Benq GL2760
   GPU: MSI GTX 970 SLI (+140 Core|+400 Mem)               Motherboard: Msi Z97-G5                                 HDD: WD blue 1TB                             CPU Cooler:  Hyper 412s
      RAM: 16GB HyperX DDR3 1600MHz                                PSU: Cooler Master v850                                 Storage: Adata HV610 1TB                  OS: Windows 10
https://linustechtips.com/topic/349566-my-first-z97-build/#findComment-4756711
Will do that. Thanks for the advice  :)
https://linustechtips.com/topic/349566-my-first-z97-build/#findComment-4765020
