The whole point of the DVI to VGA converter is to make the card usable on older monitors. As long as the monitor supports VGA, it supports the DVI to VGA converter. Do you have another display to use? Does your display support anything other than VGA?
https://linustechtips.com/topic/349560-huge-problem/page/2/#findComment-4761910
used another monitor and the same problem occurs.. can someone tell me there's something wrong with the mobo? 78lmt-s2p rev5 , can i switch it from uefi to legacy? because i saw many ppl had and the same problem and it was solved by that but i cant find how to switch from uefi to legacy?!!
the gpu name : r9 285 sphhire dual-x oc (UEFI)
https://linustechtips.com/topic/349560-huge-problem/page/2/#findComment-4761954
first time to hear that the bios should be updated for a new GPu, i know that might happens only with CPUS, also i have omega driver installed because i used to have
amd gpu , and my problem here is NO DATA the screen stays black, i tried DVi-I and DVI-D both of THEM doesn't work and tried the DVI-D on the board slot not the gpu and it doesnt work either.. so its the convertor problem? and i also tried the DVI-I on another gpu and its the same results ! it might be the monitor doesnt accept any convertor? that might happen? or what the hell is going on ?!!!! PLEEEEEEEEEEEEASE HELPPPP 2days until now and i feel like i just lost my money !
Specs:
CPU: FX-6300
GPU: r9 285 dual-x
MOBO: s2p-78lmt rev.5
ram : 4gb ram
psu: thermaltake smart se 730w
HDD : WD 500GB
Monitor : LCD ACER 19inch 1366x768 only VGA also tried on lenovo 1280x1024 LCD VGA/DVI-D
Did you update the BIOS, or did I read your incoherent ramblings correctly that you did not?
If you aren't going to take our suggestions you can just mark the topic as solved now because we aren't going to help you if you wont cooperate.
Stop double posting. We have jobs, we don't get paid to help on the forum we do it out of the goodness of our hearts and free time.
Stop being impatient for something you're getting for free, just calm down and we will get to your problems. We have lives too you know.
EDIT: Got to page two. You're breaking the CoC now. Fucking. Chill. WE WILL GET TO YOUR PROBLEMS AFTER OURS.  I'm sitting at work taking my break to write this, and i'm sure i'm not the only one.
How about instead of fighting us on this, just install the drivers? God damn. Sure, in a perfect world drivers wont matter at that point, but JUST DO IT. For the sake of troubleshooting.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/349560-huge-problem/page/2/#findComment-4762935
yea seriously we really dont mind helping you on here but when you get pissed off at us because WE cant fix YOUR problem, it makes us not even want to try.
anywho listen unplug everything take out your ram take out your gpu unplug your psu. replug in everything. if that doesnt fix it make sure you have the correct drivers installed. just because a driver is installed doesnt mean its the right one. and last but not least. if you have another computer laying around maybe try putting the graphics card into that other computer and see what it does even if its an old piece of shit if your graphics card works maybe its the pci slot on the mobo.
https://linustechtips.com/topic/349560-huge-problem/page/2/#findComment-4763071
hey hey calm down i didn't fight here.. and the problem is solved by returning back to the shop and the seller changed the card for another r9 285 , the card was the problem and it was fcked up.
You were clearly arguing with us; Mark the topic as solved.
https://linustechtips.com/topic/349560-huge-problem/page/2/#findComment-4769429
