Hello LTT forums!
Was wondering if you guys could take a look at the part list i've created and let me know if everything is compatible or let me know if im doing something wrong. Trying to keep the base total to about $1,350, and this is the best I could do. Any help would be greatly appreciated.
Thanks! :)
http://pcpartpicker.com/p/tpsmHx
https://linustechtips.com/topic/349458-will-this-build-work-out/
Hello LTT forums!
Thanks! :)
You could probably throw in an ssd and still keep it under $1350.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/349458-will-this-build-work-out/#findComment-4755173
Solid build. Would think about changing from corsair psu to evga for better quality. Also check other cases for same price like nzxt h440 and enthoo pro.
CPU: i7 4790k @ 4.4 GHz                                                 Case: Fractal Design Define R5                       SSD: Samsung Evo 850 250gb          Monitor:  Benq GL2760
   GPU: MSI GTX 970 SLI (+140 Core|+400 Mem)               Motherboard: Msi Z97-G5                                 HDD: WD blue 1TB                             CPU Cooler:  Hyper 412s
      RAM: 16GB HyperX DDR3 1600MHz                                PSU: Cooler Master v850                                 Storage: Adata HV610 1TB                  OS: Windows 10
https://linustechtips.com/topic/349458-will-this-build-work-out/#findComment-4755232
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($129.99 @ NCIX US)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($88.54 @ Amazon)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($323.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.79 @ OutletPC)
Wireless Network Adapter: Asus USB-N53 802.11a/b/g/n USB 2.0 Wi-Fi Adapter  ($34.29 @ Amazon)
Monitor: AOC i2267Fw 60Hz 22.0" Monitor  ($129.99 @ Amazon)
Total: $1313.45
Generated by PCPartPicker 2015-04-16 18:31 EDT-0400
This is better. I'm not sure about the wireless adapter, but I presume you've done the legwork on it.
https://linustechtips.com/topic/349458-will-this-build-work-out/#findComment-4755462
Looks good.
I have a few suggestions though:
Upgrade HDD to a 3TB for about $16
A Xeon E3 1231 V3 will provide double  the threads but cannot overclock +$30
More PSU wattage, Seasonic, Corsair, Rosewill, EVGA, and Antec are all great brands to choose.  More wattage so you can SLI later down the road.  (aim for 700W+ for a comfortable 970 SLI)
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/349458-will-this-build-work-out/#findComment-4755513
Just a thought: According to http://www.tomshardware.com/forum/id-1804779/power-supply-unit-tier-list.html, the Corsair CX/CXM series isn't quite ideal for terribly serious overclocking. Completely fine for everything else though.
EDIT: According to the link, the 750w PSU recommended by Deomons Wrath seems to be much better "EVGA Supernova B2 series (may even reach 80+ Silver, according to Jonnyguru)", and cheaper. (Yours Truly has the exact same one)
Not sure how much people care about PSUs, but out of habit, I try to recommend going for a good one when for overclocking.
I don't do signatures.
https://linustechtips.com/topic/349458-will-this-build-work-out/#findComment-4757010
Don't get Corsair CX, it's a budget unit and I'd only use it for office builds, if that
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/349458-will-this-build-work-out/#findComment-4758351
https://linustechtips.com/topic/349458-will-this-build-work-out/#findComment-4759925
In terms of wireless adapters, the convenience of being able to move around USB-reliant ones is great and all, but for a desktop PC, I'd get a PCI Express adapter. They tend to have better raw speed and antennas. I personally use this one and have no complaints (Link). I only have an N300 router anyways, so anything faster wouldn't do anything for me.
Of course, if you can get a wired connection, go for it. PowerLine adapters are also a thing.
https://linustechtips.com/topic/349458-will-this-build-work-out/#findComment-4760032
