HI all,
I would like to know is this build good or i need to change something. Mostly it for gaming: Skyrim (moded), The Witcher 3, Battlefield 4, GTA V and similar games also sometimes like to mess with 3d max, photoshop.
Didn't include case since i have one lying around (http://www.coolermaster.com/case/mid-tower/k280/) or should i buy Corsair carbide series 500R it around 119 USD. Also i don't know about PSU its cheaper one so if you have better suggestions would be nice.
P.S. My budget is up to 1500 USD, another thing is it enough 650w PSU for SLI 2 GPU's in the future?
Thanks for your help :)
Opps :D
http://pcpartpicker.com/p/2trmHx
https://linustechtips.com/topic/349381-my-first-build/
HI all,
I would like to know is this build good or i need to change something. Mostly it for gaming: Skyrim (moded), The Witcher 3, Battlefield 4 and similar games also sometimes like to mess with 3d max, photoshop.
http://pcpartpicker.com/parts/partlist/
wrong link, you must use the permalink not the url
Longboarders/ skaters message me!
https://linustechtips.com/topic/349381-my-first-build/#findComment-4754212
Dude I created the same EXACT pc for a friend.
Did you copy? Like down the model number on the TP-link thing! Everything is exactly the same.
My PC/ CPU: Intel i5-4690k with ColerMaster Hyper Evo 212 / Motherboard: Asus Z97-AR GPU: EVGA GeForce GTX 750 Ti / OS: Windows8.1 / RAM: G.Skill Ares Series 2x4 1600Mhz / Storage: Seagate Barracuda 1TB 7200RPM Optical Drive: ASUS 24B1ST / Network: TP-Link WN881ND /////////////////////////// If I fail to respond to your questions, please message me! Thank you
https://linustechtips.com/topic/349381-my-first-build/#findComment-4754269
Builnd N1: ( Expensive one )
Case: Nzxt h440
Psu: EVGA SUPERNOVA 750 G2
MSI Z97 Gaming 7
Ram: G.Skill Ripjaws X  2x4 1866mhz
Cpu: i7 4790k
Cpu Cooler: Kraken X61
Gpu: MSI GTX970
SSD: Samsung 840 Pro 128gb
HDD: WD 1TB
Build N2: ( Cheap one )
Case: Nzxt h440
Psu: Corsair 650vs
Motherboard: MSI Z97 Gaming 3 / 5
Ram:  G.Skill Ripjaws X  2x4 1600mhz
Cpu: i5 4690k
Gpu: MSI GTX970
HDD: WD 1TB
Here u go mate i made 2 builds for you. Look my builds and choose parts from this i guess
Project Redline:
♦CPU: i7-5820k  ♦CPU Cooler: Kraken x61 ♦Mobo: MSI X99A SLI ♦RAM: G.Skill Ripjaws 4x4GB 3200mhz ♦GPU: Evga 980Ti Hybrid ♦Case: NZXT H440 ♦SSD: Samsung 850EVO 500GB ♦HDD: WD BLUE 1TB 7200rpm ♦Display: 1280 x 1024
https://linustechtips.com/topic/349381-my-first-build/#findComment-4754284
who makes that PSU?
If you gonna get over 100$ psu, better just be seasonic one, you need 600w only anyway.
some RM series are just poor.
IDK, but you have a point, it should be from evga since they have the best rma services. And over 600w because the user asked if 650w is enough to sli gpus so he probably want to do that sooner or later
https://linustechtips.com/topic/349381-my-first-build/#findComment-4754314
dude look get this build and then save for another 980 as if i was to go up to x99 it would be 1650 look good tell me what you dont like!
http://pcpartpicker.com/p/TfRzgs
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/349381-my-first-build/#findComment-4754341
No shit the link he gave brings you to the last build YOU did
:P im stupid. but you are the one with the borken link. So yeah.
https://linustechtips.com/topic/349381-my-first-build/#findComment-4754368
Wut
It is a broken link...
https://linustechtips.com/topic/349381-my-first-build/#findComment-4754495
