Another GTA V issue.
Go to solution Solved by ESPclipse,
It might not fix it but check the integrity of the game files via Steam
Hello, I've recently downloaded GTA V on my laptop. At first I was getting the error that GTA has stopped working before the game even started. So I did the whole disable the graphics card and before the game started i would enable the card again. I can play the game for about 5 minutes before it crashes and a message pops up saying that the game has exited unexpectedly. I was just wondering if anyone else is having this issue. I've looked all around to find a solution but that has not got me anywhere, so i figured I might as well ask instead of waiting for someone else to do it. I am using an MSI GT70 with an 870M graphics card. I am using the steam version.
https://linustechtips.com/topic/349351-another-gta-v-issue/
Do you have a samsung ssd?
Try to make a large pagefile on your hdd
https://support.rockstargames.com/hc/communities/public/questions/203283328-GTA-V-PC-Memory-leak
https://linustechtips.com/topic/349351-another-gta-v-issue/#findComment-4753927
