Hi guys, first post here but in need of some advice for my ITX build. I have an MSI Z87i AC motherboard in a Coolermaster Elite 120 case (a budget case I know but i'm quite impressed with it). My issue is that my current cooler - a freezer 11lp blocks one of my RAM slots, limiting me to 8GB RAM. I'm looking for a new cooler that will both be compact enough for RAM compatibility, shallow enough to allow for my cases height restraints and effective enough to sufficiently cool my 4790K - the Noctua NH-L9i fits almost all of these requirements but isn't quoted for 90watt cpu's, hence me hoping to find alternatives.
If anyone knows whether the Deepcool Gabriel-lp* would be compatible with this case/mobo/standard size RAM then please let me know, or if you know of any compatible alternatives it would very helpful! Thanks
* http://www.amazon.co.uk/DEEPCOOL%C2%AE-GABRIEL-Cooler-Profile-Heatpipes/dp/B00LSRXVA0/ref=sr_1_2?ie=UTF8&qid=1429204291&sr=8-2&keywords=DEEPCOOL%C2%AE+GABRIEL
https://linustechtips.com/topic/349321-compatible-mini-itx-cooler-help/
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
I am having a similar issue,  I am building my gf a hadron rig as it is the smallest and nicest looking rig I could think of for her as she is not a gamer and doesn't like box shaped towers.  I am looking to put a I5 4690k in it.  I am looking to overclock a few years down the road and I want to make sure she can overclock down the road.   Someone should do a form fitting showdown for just this type of issue haha.
