Inspired by the 5960X vs G3258 video by Linus, I decided to give the Pentium the best chance to reach a high overclock.  This build is only for curious games (like me), not the video producer!
CPU: Intel Pentium G3258
NCIX: http://www.ncix.com/detail/intel-pentium-g3258-anniversary-unlocked-d2-97890-1079.htm
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16819117374&ignorebbr=1&cm_re=Intel_Pentium_G3258-_-19-117-374-_-Product
Motherboard: Asus Maximus VII Formula/Watch Dogs
NCIX: http://www.ncix.com/detail/asus-maximus-vii-formula-atx-f0-100602.htm
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16813132247&cm_re=Asus_Maximus_VII_Formula%2fWatch_Dogs-_-13-132-247-_-Product
Memory: Corsair Vengeance LP DDR3 1866
NCIX: Not Available
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233240&cm_re=Corsair_Vengeance_LP_DDR3_1866-_-20-233-240-_-Product
GPU: EVGA GeForce GTX 980 Classified ACX 2.0
NCIX: http://www.ncix.com/detail/evga-geforce-gtx-980-classified-02-104475.htm
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487084&cm_re=EVGA_GeForce_GTX_980_Classified_ACX_2.0-_-14-487-084-_-Product
PSU: Thermaltake Toughpower DPS G 550W
NCIX: Not Available
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16817153210&ignorebbr=1&cm_re=Thermaltake_Toughpower_DPS_G_550W-_-17-153-210-_-Product
Case: Cooler Master N400
NCIX: http://www.ncix.com/detail/coolermaster-n400-atx-mid-tower-97-86797.htm
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119277&ignorebbr=1&cm_re=Cooler_Master_N400-_-11-119-277-_-Product
HDD: Western Digital Black 3TB
NCIX: http://www.ncix.com/detail/western-digitial-wd3003fzex-black-3tb-cf-92800-1079.htm
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16822236623&ignorebbr=1&cm_re=Western_Digital_Black_3TB-_-22-236-623-_-Product
SSD: Samsung 850 Pro 128GB
NCIX: http://www.ncix.com/detail/samsung-850-pro-2-5in-128gb-c2-99903-1079.htm
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147359&ignorebbr=1&cm_re=Samsung_850_Pro_128GB-_-20-147-359-_-Product
Media Drive: Asus DRW-24B1ST/BLK/B/AS
NCIX: http://search.ncix.com/products/?sku=DH8888115052
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204&ignorebbr=1&cm_re=Asus_DRW-24B1ST%2fBLK%2fB%2fAS-_-27-135-204-_-Product
Case Fan: 3x Cougar 12CM CFG Red LED
NCIX: http://www.ncix.com/detail/cougar-cfd120-red-led-120mm-d7-84956-1290.htm
Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16835553010&ignorebbr=1&cm_re=Cougar_12CM_CFG_Red_LED-_-35-553-010-_-Product
CPU Cooler: Swiftech H240-X
NCIX: http://www.ncix.com/detail/swiftech-h240-x-all-in-one-liquid-cooling-6d-102715.htm
Newegg: Not Available
Let me just start by saying, this is a very impractical build, and I would never recommend it.  This is also my first post, so constructive criticism is always welcome!
https://linustechtips.com/topic/349014-pentiumto-the-max/
Well if it fails epically you can always throw a i5 in it =P
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/349014-pentiumto-the-max/#findComment-4749664
Great idea! Not really...not at all...
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/349014-pentiumto-the-max/#findComment-4749685
Lets also note that most games won't work on a Dual core processor. Some are fixed by the 9th patch(there are always 8 the first day).
Most? Dude, the "Need 4 cores to even boot" hype thing started with Far Cry 4 and ACU back at launch. Those games aren't that old.
"A few games" is a more precise statement.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/349014-pentiumto-the-max/#findComment-4749928
