I want to start streaming and I'm wondering is my 4790K capable of streaming games while I play a high demanding game with no problems.
I don't want to spend money on xSplit if I know I losing performance doing so? I still want my computer run smoothly.
As long I can play games in 2K at 60+ FPS I'm happy.
While I can still multitask while streaming smoothly
https://linustechtips.com/topic/348998-streaming-questions-help/
should be fine. professional streamers use the i7, so you will be fine.
I wouldn't bother buying Xsplit, just use OBS. it free, and just as good.
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
https://linustechtips.com/topic/348998-streaming-questions-help/#findComment-4749578
