Hey guys, so I just got my K70 yesterday, and I'm just really playing around with automations and animations and stuff. So I got a few right, but when I log into steam, it crashes all animation, like it just stops working. I've tried switching profiles after steam has launched, but it hasn't worked. If anybody could help, I'd be very gracious. Thanks!
Sally: l Intel i5 4690k | | Corsair H55 | | Zalman z12 plus | | Hitachi 2TB HDD | | Samsung 840 Pro 128 GB | | ASRock Fatal1ty z97 Killer | | Corsair Vengeance 16 GB | | EVGA SuperNova 750 watt | | MSI 390 | | Windows 10|
https://linustechtips.com/topic/348965-k70-steam-problems/
I have the same issue with my k65, you need to unplug it and plug it back in and it should work. It's something with the corsair utility software that causes the issue and there's really nothing you can do until they update it.
CPU: AMD Ryzen 9 3900x  GPU: ASUS Strix rtx 2080 Super RAM: Corsair Vengeance Pro RGB 8gb x4 PSU: Corsair HX850i Motherboard: ASUS Strix x570-E Storage: Samsung 840 pro, Samsung 970 evo 1tb nvme, segate 2tb Case: NZXT H510I Cooling: Corsair h100i
https://linustechtips.com/topic/348965-k70-steam-problems/#findComment-4749133
Thanks!
https://linustechtips.com/topic/348965-k70-steam-problems/#findComment-4749146
when it freezes change the polling rate also run steam as admin whenever steam crashes just change the polling rate wait 30 seconds and it should be fine. also make sure you're saving to device memory
https://linustechtips.com/topic/348965-k70-steam-problems/#findComment-4749155
Glad I don't have this issue. Had my corsair utility software crash on me with Shootmania launcher.
BTW does your windows bootbup as its supposed to do or does it stay on your motherboard manufacture logo screen for far too long ? (Mine does....)
I have RGB version.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/348965-k70-steam-problems/#findComment-4752321
I have RGB version.
longer than it did before, at one time i thought it was hanging, waited 20s boots right. Sometimes it takes a sec before i can type on my login screen too.
https://linustechtips.com/topic/348965-k70-steam-problems/#findComment-4752400
I have RGB version.
mine does that now sometimes, too
https://linustechtips.com/topic/348965-k70-steam-problems/#findComment-4752675
