i was building my new PC and i got a 300r case one thing i noticed was that it only came with 1 riser screw for the mobo the holes where the screws go are raised enough already. i was too  lazy to call support so i just got some that were the same size from my old case, when i put my mobo on it it didnt fit into the i/o shield and then i didnt get why they only ave me one riser screw with my case, so im so running my pc without any riser screws i dont know if they do only igve you 1 and its safe not to put all of them in or the retailer(microcenter) did something wrong
Space Journal #1: So Apparently i  was dropped on the moon like i'm a mars rover, in a matter of hours i have found the transformers on the dark side of the moon. Turns out its not that dark since dem robots are filled with lights, i waved hi to the Russians on the space station, turns out all those stories about space finding humans instead of the other way around is true(soviet Russia joke). They threw me some Heineken beer and I've been sitting staring at the people of this forum and earth since.
https://linustechtips.com/topic/34886-carbide-300r-help/
most of them are already on the motherboard, they are the raised parts where a standoff should be, i have this same case and it only came with 1 standoff.
[ I7-4770K ][ Gigabyte GA-Z87-UD3H ][ Corsair Dominator Platinum 16gb ][ Corsair Carbide 300R ][ Corsair HX850 ][ Gigabyte Gtx 770 ]
[ Samsung 840 Series 500gb SSD ][ Bitfenix Spectre Pro (Blue LED) + Bitfenix Recon Fan Controller ]
https://linustechtips.com/topic/34886-carbide-300r-help/#findComment-446694
wait, from what i can see from the picture of the case on the internet, you dont actually need that much of risers to mount your motherboard. that case has 'bump' on it that act as the riser itself. My 500r has that 'bumps' too but i still need a few risers to mount the motherboard. as far as putting only one riser, as long as the motherboard is screwed onto the case flat, without bending/distorting it,you are good with it.
https://linustechtips.com/topic/34886-carbide-300r-help/#findComment-446707
oh ok so nothing to worry about. when i first saw it, i was a head scratchier for me
https://linustechtips.com/topic/34886-carbide-300r-help/#findComment-446813
