USB wireless adapter
Go to solution Solved by Zgypt118,
btw..if you have the option...you should use a powerline adapter kit instead of wireless
Well after reading a little on it I think I will go with this option, thank you.
theres hardly any difference
its just a matter of how much you wanna spend
I would just sort it by reviews and pick the best one in your budget
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/348857-usb-wireless-adapter/#findComment-4747818
https://linustechtips.com/topic/348857-usb-wireless-adapter/#findComment-4747820
