we're meant to know what your cpu is how?
edit-its an fx4 isnt it.
set multi to 20, turn off turbo
set voltage to 1.4 and test for stability, make sure your HT and NB is under 2200.
if it fails raise voltage a bit and try again.
same as any fx8350 overclocking guide
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4745576
it is fx6300
And could you be specific on what I have to change in the image, since this is my first time overclocking.
Thanks Miniman
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4745599
it is fx6300
Thanks Miniman
what board do you have?
cpu clock ratio-20
cpu northbridge-11
core performance boost-disables
(auto from here)
cpu voltage control-1.4v
cpu loadline calibration-0% or "normal" or whatever
cool n quiet-disabled
bot into windows and see what cpu-z says your stock volts are (write them here once you know)
open cinebench and watch the votls as it does the test and see how much it drops.
go back into bios and put the laodline calibration up a notch untill the voltage under cinebench matches stock/idle volts
also open coretemp and see what it says your stock "vid" is down the bottom and write that here too.
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4745636
post-198816-0-10975400-1429122898_thumb.
cpu clock ratio-20
cpu northbridge-11
(auto from here)
So I done everything you advised, I booted up fine and was really happy, checked cpu-z and was running at 4.0ghz  :) and the temps where fine at 20-35c
But the I opened cinebench and started the cpu benchmark and ran into a pc crash... What should I change in the bios to stop this from happening
All the information, is on photo, here they are:
post-198816-0-94710200-1429122905_thumb.
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746100
dont worry abotu crashing screen shots from here, but take a print screen of cpu-z in (stress) and cpu-z in idle, and coretemp at load.
press alt+PrScn maybe 3 seconds after you start the test then stop it by exiting cinebench.
then paste it into paint, save it and upload that.
im guessing your cpu VID is 1.275 which means 1.4v should be more than enough, in fact depending what board you have (still dont know) it mgiht be too much for the vrm's (unsure) so try it at 1.3v instead
to clarify..
system voltage control-manual
cpu voltage control-1.3v
cpu vcore NB (northbridge/memory controller) 1.2v
and then go into wondows and get those screenshots.
ill reboot myself to get you some examples.
EDIT-heres the sort of thing to do..
Fx6 4ghz idle
Fx6 4ghz load
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746198
to clarify..
Hey, so I have done the cinebench thing and screenshot cpu-z and for the temps at idle it is at 17-21c and when cinebench is rendering it is 30-40c
When IDLE -https://drive.google.com/file/d/0B4vcB0tbrwWEcTlpZi1xcVQwRVZ2enBYMk9ub053UmQtLUJB/view?usp=sharing
When stressed - https://drive.google.com/file/d/0B4vcB0tbrwWEYWxTRm9rVjlLemsxcUJNVGdSbHQ3SnB6Z0Fn/view?usp=sharing
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746398
Edit - those screenshots are from before when it crashed
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746466
yep, you see how the voltage during stress is much lower? thats vdroop (google it)
what motherboard do you have before we go any further.
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746572
yep, you see how the voltage during stres is much lower? thats vdroop (google it)
Hey
I done the changes to the voltages and stuff, and the cpu and opengl test on cinemabench, with no crashes.
My motherboards is : http://www.gigabyte.com/products/product-page.aspx?pid=4125#ov
my core voltage idle now : 1.284-1.300
my core voltage stressed now: 1.400-1.600
Thanks for the help, should I do Prime95 now for a stress test
EDIT - I read about Vdroop, do you think it is ok for how much it droops?
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746701
Hey
reduce your loadline, voltage under stress should be as low as possible (but no less than idle), 1.5+ is not good
what options for loadline calibration do you get? a percentage like "5%" or "low", "medium, "high"?
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746744
How would I do that?
have a look in the cpu section where the FSB and voltage is and look for "loadline calibration" or LLC etc if you find it set it to medium or 5%(ish) and retest but let me know what it says.
(on my old m5a78l-m/usb3 it was a percentage and i often set it to 3% just to give it something under load as it didnt vdroop much.)
edit- you have a 3+1 phase vrm which will severely restrict any overclock you do.
rather than push beyond 4ghz i would recommend seeing how low you can get the voltages to be while maintaining stability.
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746805
Hey,
So I have changed the voltages and lowered them and now:
idle: 1.248-1.272
Stressed: 1.224
Is that any better, or should I change anything?
EDIT - could not find the other thing you saying to put at 5%
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746956
Hey,
idle: 1.248-1.272
Stressed: 1.224
Thats allot better, it might be worth seeing if you can get the stressed voltage to around 1.3 though as its more liekly to be a stable setting (from experiance) rather than having to increase it bit-by-bit, so 1.25-1.3 idle, and 1.275-1.325 load would probably be a great start.
if you can get that then see if it passes cinebench. AND monitor coretemp not only for temps but see if the speed drops to less than 3.95ghz, if it does drop down to 2ghz or so during the benchmark then your vrm's are likely throttling to prevent damage, but lets not focus on that unless it happens.
if it passes cinebench without throttling post your results here.
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4746980
Idle: 1.284
stressed: 1.236
Better or worse
EDIT - temps are fine and no throttling
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4747250
Idle: 1.284
stressed: 1.236
Better or worse
well if its not downclocking and your temps are fine then its time to start stress testing, try amd overdrive's stress test which has a 1hour preset, then if you like try prime 95 blend for an hour and if it passes you should be good.
if for any reason it fails try and get that load vcore to 1.3v
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4747304
Is this better???
Idle - 1.282 - 1.308
Stressed 1.650-1.700
will do the stress testing tomorrow
and thanks for all the help :)
EDIT - when I checked my task manager it told me I was running at 3.92ghz I dont mind but is it a problem?
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4747363
Is this better???
1.650-1.7 is kinda too high for my tastes. what are your temps like?
I refuse to read threads whose author does not know how to remove the caps lock!
— Grumpy old man
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4747638
Is this better???
thats really wierd, i think the second your board detects 1.3v it puts the LLC way too high, its probably better to run it too low than too high as you;ll kill your board with anything over 1.45v.
put it to 1.25v ish and call it a night. 3.92ghz is fine, depending on how stable it is you might be able to get 4.2ghz on 1.25v (if you're lucky)
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4747650
1.65V is far to high, even on a good board 1.5 is the maximum limit even for benching, 1.45v is a good maximum for daily use, he has a low VID chip at 1.275v which is good as it should still remain stable at low volts but his board has a poor vrm so the total power he can draw is very low.
because of this he needs to keep his voltage as far down as possible which would be good temps wise.
if he can be stable at 1.25v at 4ghz thats good and his temps will likely be <50*c under load.
https://linustechtips.com/topic/348686-overclocking-help-please/#findComment-4747674
