Hello! I've been using Macs to play games on for the past few years, as I've had parallels/boot camp or just waited for Mac port/version. How ever now I feel I would be better off investing In a Desktop PC since I would like to play more resourceful games in maxed out/ultra settings without lag, as I'm trying to use GTA V on Mac and its hell + other games I've played and they lag.
I'm not to sure on all the PC terminally or specs, and I know you can get pre built or custom made ones. I've been looking on curries PC world and have found this machine, it looks relatively okay and I was wondering if anyone would know if I could play games like GTA V maxed out settings etc?
http://www.currys.co...-pdt.html#cat-0
The computer above seems highly priced from what people have recommended, my budget for this build will be £800 and I'm looking into building one however I have no idea which company or what kind of CPU, GPU and motherboard I need. I've checked the PC specialist out (I'm in the uk) and hey seem to be a popular pc custom build company, are there any others?
Thanks for reading! :)
https://linustechtips.com/topic/348188-first-time-pc-help/
This is not in the right subforum man. I'll have it moved.
https://linustechtips.com/topic/348188-first-time-pc-help/#findComment-4739413
You can get better things for dat price. Just drop ur budget and ppl will collect u smthing. How much u can afford?
CPU: i7 4790k @ 4.4 GHz                                                 Case: Fractal Design Define R5                       SSD: Samsung Evo 850 250gb          Monitor:  Benq GL2760
   GPU: MSI GTX 970 SLI (+140 Core|+400 Mem)               Motherboard: Msi Z97-G5                                 HDD: WD blue 1TB                             CPU Cooler:  Hyper 412s
      RAM: 16GB HyperX DDR3 1600MHz                                PSU: Cooler Master v850                                 Storage: Adata HV610 1TB                  OS: Windows 10
https://linustechtips.com/topic/348188-first-time-pc-help/#findComment-4739462
