a friend of mine has a gtx980, and at boot it wil read 80-90 degrees celsius but it gets colder when the pc has ran for an hour (40-50 degrees) is this just temp sensors being what they are (innacurate peices of sh!t)?
(im pretty shure its just the temp sensors being all weird on him but he insists i ask you guys and girls)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/347093-gpu-heat-problem/
Change thermal paste- could have been applied sloppily in the factory.
a 660 i had gotten for free had thermal paste on the back of the pcb and large amounts on the front of the pcb but none where it should have been applied.
My pc:
(Black Glacier)
My server:
https://linustechtips.com/topic/347093-gpu-heat-problem/#findComment-4725264
gtx 980 ti? is this a request from the future??
sorry meant 980!
My pc:
(Black Glacier)
My server:
https://linustechtips.com/topic/347093-gpu-heat-problem/#findComment-4725411
This^^
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/347093-gpu-heat-problem/#findComment-4726705
Done the paste has been replaced and thurough cleaning the heatsimk fins did the job
My pc:
(Black Glacier)
My server:
https://linustechtips.com/topic/347093-gpu-heat-problem/#findComment-4726947
