Maybe it's your mouse ;)
I would guess coil whine
Atom14 [Corsair] i5-4690K | Corsair H110i GT | MSI Z97S SLI Krait | 16 GB Team Group DDR3 | Samsung 850 EVO 250GB X2 | EVGA SuperNOVA 850W 80+ Gold | Corsair K95 RGB | Corsair M65 RGB | EVGA ACX 2.0 GTX 980Ti
Corsair KXX RGB Keyboard Cover Mod Make your own using my templates!
https://linustechtips.com/topic/347091-squeaking-noise/#findComment-4725233
No I dont think it is that because it is not on constantly
Well, if it happened only when your PC works hard, it can still be coil whine. You know the sound and your PC best though, so your guess is probably better than mine.
https://linustechtips.com/topic/347091-squeaking-noise/#findComment-4725259
It does it most of the time, Do you reckon that having my PSU fan pushing air directly into the GPU fan could create it
https://linustechtips.com/topic/347091-squeaking-noise/#findComment-4725269
I don't know of any PSU that pushes air... Don't they all pull air out of the case? Anyhow, the GPU or PSU is most likely the culprit dealing with coil whine. I would see if moving th GPU to another slot or flipping the PSU does anything (if it is pushing air into the GPU. Sorry, I just never heard of a PSU pushing air, lol)
https://linustechtips.com/topic/347091-squeaking-noise/#findComment-4725284
