I've been meaning to upgrade my PC for a couple of months now and I need some recommendations and or input!
CPU: AMD FX-4350 Quad 4.2
GPU: MSI R9 280x 3GB
MOBO: AsRock 970 Pro3 R2.0
8gb RAM HyperX Red Series 1600
PSU: Corsair CX750
Windows 8.1 OEM (edit: full version)
I am thinking of upgrading to the AMD FX-8350 and I feel like I would need a on par mobo to go along with it. I also just purchased the h100i to kick of the upgrade.
Also a little side question, if I were to upgrade my mobo, could I just swap the mobo or would I have to completely purchase a new copy of windows 8.1?
Any recommendations or input on what I should and shouldn't be doing?
Thank you!
https://linustechtips.com/topic/346923-upgrade-advice/
If you switched the mobo while you had Windows already installed, a fresh install is needed.  I don't know about your budget, but I'd personally go with an i5 instead of AMD,
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/346923-upgrade-advice/#findComment-4723180
8gb RAM
PSU: Corsair CX750
Windows 8.1 OEM
Thank you!
Go intel. i5 4590 would be good if you dont overclock. You will need to rebuy windows, and then get a new motherboard, any h97 mobo will do. h100i isnt necessary, your components will run cool enough with an air heatsink such as the 212 EVo which works great.
And please dont type with a black background
Im so patriotic, I piss red white and blue. My doctor told me it was pancreatic cancer, I told him to SHUT HIS COMMIE MOUTH.
-A shotgun wielding redneck
https://linustechtips.com/topic/346923-upgrade-advice/#findComment-4723181
If he isn't overclocking he could go with the Xeon 1231 V3?
https://linustechtips.com/topic/346923-upgrade-advice/#findComment-4723195
Sorry about the black background, copied the post I made about an hour ago from Tek Syndicate bc no one was replying. Thank you for your response though!
https://linustechtips.com/topic/346923-upgrade-advice/#findComment-4723199
Get a 4690K, Z97 mobo, you'll need to rebuy windows. You may also want to include the specific details of your ram. Is it 1600?
As much as it is a minor uprade, maybe a 290 would be nice in there too, although it might not be worth it for $400 (AUD)
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/346923-upgrade-advice/#findComment-4723203
Personally I'd go Intel if you're upgrading, especially if you're replacing the motherboard. The AMD chips are so old at this point.
You don't have to rebuy Windows. A lot of the time you can reinstall it just fine. If not a simple call to Microsoft will often work.
Also Z97 motherboards are often cheaper, if not so similar in cost that getting them over an H87 motherboard makes more sense. Depends what his needs are.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/346923-upgrade-advice/#findComment-4723241
those mobos dont come too cheap
What? You can run it on a B85 board. Those are ~$50.
https://linustechtips.com/topic/346923-upgrade-advice/#findComment-4723246
It's an LGA1150 CPU according to http://ark.intel.com/products/80910/Intel-Xeon-Processor-E3-1231-v3-8M-Cache-3_40-GHz
Also check your Windows License. I've changed motherboard without buying a new copy of Win7 Ultimate. They should have a number of Re-Arms. If they haven't ran out, Microsoft should be able to transfer the license to the new PC (Locks to Mobo AFAIK).
Run the command
slmgr.vbs /dlv
in CMD to check the licensing status.
Edited by Casperian
https://linustechtips.com/topic/346923-upgrade-advice/#findComment-4724238
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.95 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($332.99 @ Amazon)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($35.96 @ Amazon)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($37.99 @ NCIX US)
Total: $742.12
Generated by PCPartPicker 2015-04-13 03:45 EDT-0400
If you want to go the intel route.
https://linustechtips.com/topic/346923-upgrade-advice/#findComment-4725060
