Hello all,
I recently built a gaming PC with some money I earned. Currently, I'm not using good peripherals necessarily the best for gaming. My build is red and I'd like to be able to color match my keyboard, mouse, and headset to the build. I've been looking into Razer's Chroma line and am thinking about purchasing them from there, however I know Corsair makes an RGB line and wanted to get any recommendations others may have for RGB gaming accessories.
https://linustechtips.com/topic/346691-rgb-peripheral-recommendation/
Hello all,
Well Corsair is significantly better between the two keyboard offerings of the K70 and Blackwidow Chroma. Avoid the Razer keyboards and you're solid basically.
As for the mouse, the Deathadder Chroma isn't terrible, though Razer build quality makes me shiver so please get yourself an extended warranty.
Thanks for the advice. Anything to recommend in terms of headsets?
I suggest asking the audio subforum :) I don't do audio so much.
Hello all,
Please don't buy any of the corsair rgb keyboards. The corsair tramp stamp is yellow.... and rgb peripherals are made to MATCH with everything else, not stick out. You're better off just choosing a single color and then doing your peripheral shopping off of that.
If you want a decent keyboard without a tramp stamp to be rgb, get a backlit keyboard and use this: (https://www.massdrop.com/buy/led-color-changer)
the tramp stamp takes 2 mins to take off and change. If your going to hate on anything pick the the software.
