Ok guys I need help building my new computer, I don't really know what parts will work best for what I need
The budget is $2500 US dollars. I will be gaming at 4k. I don't need windows or keyboards or things like that. Just the computer. The processor and graphics processor MUST be amd. Thank you all for your help, Linus community
CPU AMD 9590 -- 2x Titan X ---  RAM 32GB KINGSTON---PSU EVGA 1000 ------ HARD DRIVE 2TB WD BLACK -- MOTHERBOARD AMD 900 SERIE
RAZER CRACKEN ---------RAZER NAGA -------------------RAZER CHROMA
english is new language for me so forgive my many mistake / I have moderate autism so im not always correct
https://linustechtips.com/topic/346259-need-help-2500-amd-build/
If the video card has to be AMD, you should probably wait for the 300 series.
CPU: i7-4790K --- HEATSINK: NZXT Kraken X61 --- MOBO: Asus Z97-A --- GPU: GTX 970 Strix --- RAM: 16GB ADATA XPG --- SSD: 512GB MX100 | 256GB BX200 HDD: 1TB WD Black --- PSU: EVGA SuperNova G2 --- CASE: NZXT H440 --- DISPLAY3 x Dell U2414H --- KEYBOARD: Pok3r (Clears) --- MOUSE: Logitech G Pro --- OS: Windows 10
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715515
May we know why it must be amd?
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715517
At $2500 I would NOT recommend going with AMD for the CPU, intel's processors are a much better choice.
You'll probably end up with a bottleneck from your CPU if you go with AMD for it, especially on more CPU-demanding titles.
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715518
I've always liked amd better, they have been in all of my past computers. My friend who got me into pc gaming recommend I get AMD because they are already at 9000 while Intel is only at 4000. The prices are much better also. The 8 core AMD one is very cheap
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715544
Do you mean 9000 by the processor name like 9590 or 4790k? If you do, the higher the number doesn't necisarrily mean greater performance between cpu brands, maybe within the brand but not between AMD and intel. Intel cpus destroy amd ones, just letting you know.
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715567
You've always liked AMD better, but that doesn't mean they are better.
You are seriously biased to them for a larger number? That's like me saying the GTX 960 is way better than the R9 295x2 because it's 900 series vs 200 series. AMD's current CPUs run on a two year old architecture, they're slower than what Intel offered even back then.
I know it sounds like I'm being a fanboy here, but go look at any modern benchmark. Even i3s are pulling ahead of the FX 8350 for gaming.
As for GPUs, AMD are making fantastic GPUs right now, so I can't say anything bad on that front other than "get your damn power consumption down."
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715569
Well clearly your friend knows very little.
Do NOT use model numbers as the only thing you're comparing, especially between brands or product lines, compare the performance, not the name.
If you're using a GPU, then the integrated graphics of the CPU don't matter at all either.
Just because some of AMD's 8 cores are cheap, does not mean they are amazing, when it comes to single-threaded tasks, my i5 4690K (4 core) destroys the fx 8350 which is one of AMD's top processors, and in multi-threaded tasks my i5 comes pretty close to the fx 8350.
AMD's processors have lots of weaker cores, whereas intel's processors have fewer more powerful cores.
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715575
He has a 4770k, but my current computer has a AMD a 5400 and it does very good in my games. They perform about the same so that's why I thought the number mean something. Doesn't the only thing that powers the game is the graphics processor?
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715583
I'm sorry, but comparing the number in the name of processors between AMD and Intel is just hilarious.
Just because a 9590 is OVER 9000 doesn't mean it tops the 4790K, or even the 5690X. Tell your friend to know what he is talking about before he goes about spouting more bs lol.
I really am not sure what to say lol, please just look around in this subforum, and better yet watch Linus' build guides.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715588
The GPU is the main thing that runs the game, but the CPU is almost as important. Even if you have the best GPU in the world, your CPU can only do so much.
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715589
Is that the Athlon 64 x2 5400+ or the a6 5400K?
But for either one, they do not perform nearly the same, the i7 4770K absolutely destroys both of those processors in everything.
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715590
Honestly, in most games, you'll get bottlenecked by your CPU with that kind of budget. Get an i5.
I'm saying this even though I recently bought an AMD system (8350 + R9 290), because at this point in time AMD CPUs are much better for rendering and video editing/streaming than an i3 at the same price point, but if I were to look at purely gaming, any Intel CPU (even the i3s) would wreck my 8350.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715600
It is the a6 5400. The one with the integrated graphics card
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715608
Intel says that one only has 2 cores. AMD has 8 cores. Why is the Intel one better?
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715616
Yeah, that doesn't stand a chance against the i7 4770K, or even my i5 4690K.
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715647
I will assume this is not a troll post and will be the first person to actually help you with what you're looking for instead of telling you not to go AMD.  At 2500 you will be able to rock a sick system aside from the CPU.  But you already know that from all the above posts!  I personally would find this money not-well-spent, but to each their own!   You might want to even go bigger with a 1200 or 1600W PSU.
CPU: AMD FX-9590 4.7GHz 8-Core Processor  ($297.14 @ Amazon)
CPU Cooler: Cooler Master Glacer 240L 86.2 CFM Liquid CPU Cooler  ($134.88 @ Amazon)
Motherboard: Asus Sabertooth 990FX R2.0 ATX AM3+ Motherboard  ($174.99 @ Amazon)
Video Card: XFX Radeon R9 295X2 8GB Core Edition Video Card  ($704.99 @ NCIX US)
Total: $2233.96
Generated by PCPartPicker 2015-04-12 00:06 EDT-0400
Case: HAF XBCPU: 4690kCPU Cooler: NH D15Motherboard: Gigabyte Gaming 7 | RAM: Hyper X FuryVideo Card: G1 Gaming 970SSD: 850 EVO |  PSU: Supernova 550 G2 |
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715662
I can see why you might think the naming scheme/numbers have direct correlation with performance, but it's not that simple. Spend some time watching Techquickie videos and reading online to learn more about choosing computer components. Start with this one:
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4715669
Most games only use 2-4 threads. With an Intel CPU, that means that each core (if your CPU has 2 or 4 cores) is being used. On the AMD side, you're only using half the cores or less.
That means that for example if each Intel core can do 1000 calculations per second, and each AMD core can do 750 calculations per second (not actual figures), a program running on two threads can do 2000 calculations on an Intel CPU but only 1500 calculations on an AMD CPU. (However, in the real world that number is probably more like 1000 and 600 per core to be honest)
If you need more help, feel free to PM me! I can clarify if you want.
The benefit of an AMD CPU comes when you're doing something like video editing, as those programs can use up more than 8 threads. In that scenario, our Intel CPU can only perform 4000 calculations, whilst our AMD CPU can do 6000.
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4716130
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($101.98 @ Newegg)
Video Card: EVGA GeForce GTX Titan X 12GB Video Card  ($999.99 @ Amazon)
Case: Corsair 760T White ATX Full Tower Case  ($139.99 @ Micro Center)
Total: $2010.50
Generated by PCPartPicker 2015-04-12 03:06 EDT-0400
This build, is just as good as it can get.
Intel laughs at AMD at this price point for performance, your opinion is totally biased.
Search for some benchmarks before you make a fanboism move.
https://linustechtips.com/topic/346259-need-help-2500-amd-build/#findComment-4716258
