[CPU Cooling] Kraken X61 or Corsair H100i
Solved by The Great Sayain Man,
1. It doesn't matter if you're case if from the same or a different brand.
2. Get the Kraken. It cools better. has RGB lights, and you can use 140mm fans on it which are often quieter than the 120mm ones.
3.Obviously a 240 or 280 rad will perform better. (Unless it's a really thick rad on the smaller rad. Like the X41)
4. You're not going to liquid cool your CPU+GPU with either of those.
