so i was playing CSGO for about 2 hours and when i came off the game as it closed the computer froze with some weird red square in the top right corner and so i restarted and its fine and has been for the past hour or so what could it be? at the moment every thing is stock and the temps on both CPU and GPU where 50c give or take. do you think it was just the application that froze the computer? also i could hear people on skype and they could hear me
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/345418-strange-artifact/
Sounds normal. Sometimes Windows or some applications can freeze. Shit happens. I would wait until it happens again and then look into solving it.
https://linustechtips.com/topic/345418-strange-artifact/#findComment-4704737
yeah thats what i was thinking just wanted a second opinion
PC PART PICKER
https://linustechtips.com/topic/345418-strange-artifact/#findComment-4704744
I suggest keeping an eye on your GFX card's heat just to rule that out. Better to be safe then sorry.
yeah i have a GPU overlay on in game and to day it hasn't gone above 55c and the hottest its got is 67c
PC PART PICKER
https://linustechtips.com/topic/345418-strange-artifact/#findComment-4704768
