Hi, I'm Joe.
I'm looking to get a PC (Preferably custom built, it's cheaper) for gaming, that's not too pricey. I understand gaming rigs are expensive, but I don't want to spend a ton.
I currently use a laptop, which surprisingly runs a lot of games well but on minimum graphics, etc.
The details of it are here: http://gyazo.com/32acc45786ac56ada8494d2e120adcf2
I'd like to be able to run a variety of games on medium-high graphics settings, this is a screenshot of my steam library so you can see what sort of things I play (If it's not installed I don't play it often.): http://gyazo.com/9d2d7273b6783c854938b7be8b9c9103
Thanks!
https://linustechtips.com/topic/345326-need-help-choosing-a-rig/
Hi, I'm Joe.
Thanks!
whats your budget
https://linustechtips.com/topic/345326-need-help-choosing-a-rig/#findComment-4703746
I live in Kent, England. Budget, ideally under £750
This fits you perfectly http://uk.pcpartpicker.com/guide/DyKH99/great-gaming-build
https://linustechtips.com/topic/345326-need-help-choosing-a-rig/#findComment-4704715
If you can find your own OS then this build will allow upgrades and you can add a second card in crossfire later with it.
http://uk.pcpartpicker.com/p/4ffsgs
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/345326-need-help-choosing-a-rig/#findComment-4704717
