2things I need to confirm
1st: If I already have Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz. I can't or shouldn't buy a Corsair Vengeance Pro 32GB 4 x 8GB DDR3 2400MHz as an add on to work with my previous RAM, because the speed aren't the same then the new and better RAM would just slow down to match my Corsair Vengeance 16GB DDR3 1600MHz?
2nd: Since I have already bought the 16GB kit of 1600MHz, would it work if I upgrade by buying another 16GB or 32GB kit of the same speed (1600MHz) ?
https://linustechtips.com/topic/345037-basic-info-about-rammemory/
1. Yes the newer RAM speed will be downclocked to 1600MHz meaning you wasted the pure power of the RAMs
2. yes it should work provided both sets have the exact speed CAS and voltage
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I wouldn't recommend running two different speed rated RAMS. It may work, but the only way would be to set them all to the slowest speed.
If you bought an upgrade kit of the same speed you shouldn't have any issues. However that is not guaranteed.
LinusGGtips
Build It. Mod It. Customize It.
I don't think the amount of memory really matters since they give you different options like 16GB, 32GB and 64GB right? So it's all down to timings, voltage and clock speeds.
Kindda like putting 2 different brands of graphics card in SLI. Same gpu but different memory clocks, it will clock down to the lowest speed.
~~~SnapDragon~~~
| CPU: AMD Ryzen 9 9950X3D | CPU Cooler: Gigabyte Aorus Waterforce X II 360mm |RAM: 2x32GB G.Skill Trident Z5 Neo RGB 6000MHz | Mobo: Gigabyte X870E Aorus Xtreme X3D AI Top  | Storage: Samsung 9100 Pro 4TB + Samsung 990 Pro 4TB + Samsung 870 Evo 4TB + Samsung 870 Evo 2TB | Graphics Card: Gigabyte RTX 5090 Aorus Master 32G | Case: Lian Li Lancool 216 | PSU: Seasonic Vertex GX-1200 |
