yeah i did. blend test prime95 12+hrs and all good.
Well then grats and hey you still could up the voltage if need be and push for more.  Once I got 4.5 GHz out of my son's AMD FX 6300 I stopped with room still left in terms of adding voltage but I think I will be working on trying to get to 4.7 GHz soon which seems to be a really good overclock for that cpu on air.  Do you think you are going to push further?
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/345015-first-oc/#findComment-4699567
i tried 4.7 but temps went too high during blend test and i had to go back to 4.6. right now i have a kraken x40 but maybe later this year i get the x61, and ill try to push it maybe to 4.8
https://linustechtips.com/topic/345015-first-oc/#findComment-4699619
damn thats a good OC, specially for a FX processor. just keep in mind that FX8k series are built to reach 5ghz but yeah partnered it with good cooling :)
Intel Core i5 - 6400 <> Msi B150A Gaming Pro <> Msi Gtx 970 Gaming <> G.Skill Ripjaw 4 16Gb DDR4 2400mhz
<> Corsair CX500M <> 160 & 250 Seagate HDD <> Aerocool Strike X (Casing) <>
https://linustechtips.com/topic/345015-first-oc/#findComment-4700042
