Power cut out for a second and my computer turned off then powered back up normally (by itself). I went upstairs to get something, came down to find my computer turned off (I didn't tell it to shut down), tried to turn it back on and it wouldn't.
Can I RMA it? It should still be under warranty.
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
https://linustechtips.com/topic/344917-power-supply-dead/
Is the breaker tripped? I'd check that out before you buy a shipping label.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/344917-power-supply-dead/#findComment-4698251
How can you check that? I changed outlets from the original one. There is another PC in the room running when I checked the PSU. I'll check how many circuits there are in the room.
https://linustechtips.com/topic/344917-power-supply-dead/#findComment-4698290
From hearing about others that ave had problems out of the box that light should stay green when you press the self test something is up, if need be it should be perfectly RMA'able to Corsair. As for using another plug that should remedy the problem as long as you are not on the same circuit. To check the breaker you need to find the one for the plugs your using in the mains box in your home.
https://linustechtips.com/topic/344917-power-supply-dead/#findComment-4698336
