overclocking issues AGAIN
Go to solution Solved by Raudi_,
so i really have a strange problem here... i have a pentium g3258 and my motherboard is a gigabyte g1 gaming edition matx, so ive tried guides on how to overclock my cpu and everytime i put for example a 3.8ghz overclock and like 1.15 on the vcore it wont boot into windows and from what ive seen from other sources other people have been getting to overclock this chip to 4ghz on default core voltage but if i try that the windows starting appears but not the logo and its just stuck there forever... only successful overclock is a 4.4 ghz at 1.378 on the vcore but the overclock was unstable and caused lots of bsod's, any ideas ??
In your motherboards BIOS you should a VCCIN(also called CPU Input Voltage) set that to 1.95v and then try to do your overclock again. Haswell is funky with its input voltage.
https://linustechtips.com/topic/344877-overclocking-issues-again/
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
