I'm thinking of buying a few parts, literally only 3, so I can slap together a mini ITX miner. If I wanted to have it feed into the wallet I have setup on my main PC, how would I go about doing this. This is all using the Ziftrpool.io that everyone here is using. Also, my main is running CCMiner while I have my mining rig run SGMiner.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/344810-question-about-having-a-separate-mining-rig/
I'd recommend not bothering... at this point mining is dead to all those who don't have A) Lots of disposable money, and B ) Dedicated hashing hardware.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
Well, ZiftrCOIN has been designed to keep current ASICS, for the most part, out of the mining of it. I believe there is system memory requirement above that of what ASICS have on them as a way to deter those who would use them. It's also kinda cool because it has a feature that it's valued under $1, coins used to purchase items will have a minimum $1 value each up to 5% of the total price.
Once you get it built just use the same wallet address in your sgminer batch file as you do on your current pc, you can have multiple computers mining to one wallet
Alright cool, and thanks for all of the help Chippas. You are probably the most helpful person around when it comes to mining.
One more thing which really isn't about this, I noticed earlier there was either an ASICS or a decent size GPU farm in the pool earlier today, considering it was doing about 92MH/s.
GPU farm or a botnet, with the 5 way algorithm used for ziftrcoin designing a new ASIC for ziftrcoin would be very difficult and way too expensive to create and would not be worth the time or effort, especially with the low value of the coin currently
