Hi,
I'm looking to build a budget pc as this will be my first time doing this.
Parts I plan on using:
AMD Athlon X4 860K
BioStar A58MD
Adata XPG V1.0 OC 1600mhz 4gbx2
EVGA 500 watt psu
Segate 1tb sshd
Zotac GTX 750 ti
Deepcool Case
I was hoping someone could tell me if this build is garbage or not and whether or not I can upgrade the gpu later on perhaps to a gtx 970 without the cpu being a major bottleneck.
Thanks in advance
https://linustechtips.com/topic/344330-first-build/
Hi,
AMD Athlon X4 860K
BioStar A58MD
EVGA 500 watt psu
Segate 1tb sshd
Zotac GTX 750 ti
Deepcool Case
Thanks in advance
CPU isn't the best, could be replaced with a i5 so you have a better upgrade path and minimal bottlenecking with high-end cards. My FX-8350 struggled handling a damn R9 290
https://linustechtips.com/topic/344330-first-build/#findComment-4690390
The core i3 4160 is a better value for his budget the i5 is overkill at this price. And get the r9 270 instead of the 750 it preforms better.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/344330-first-build/#findComment-4690568
