so. whats the budget you got left for a psu ?
look at the evga supernova g2 750w
(you don'T need that anyway)
https://linustechtips.com/topic/344321-psu-help/#findComment-4690297
SAPPHIRE Vapor-X  Radeon R9 280X says you need a 700wat PSU but do i need that much this is my build so far
http://pcpartpicker.com/p/6XywZL
A good 700 will handle that rig with two of those graphics cards. If you're only running one GPU you'll be perfectly fine with a good 550W.
"Rawr XD"
https://linustechtips.com/topic/344321-psu-help/#findComment-4690319
550W will do you fine. You can find some Seasonic/SuperFlower OEM one's, on PC Part Picker I can see some Seasonic one's around $80 that'll fit you nicely?
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/344321-psu-help/#findComment-4692212
There's the Seasonic-made XFX ProSeries 550W, which is like $45 http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9 andthe SuperFlower-made Rosewill Capstone 550W, which is $40 (after MIR)  http://pcpartpicker.com/part/rosewill-power-supply-capstone550
"Rawr XD"
https://linustechtips.com/topic/344321-psu-help/#findComment-4695728
I would recommend the Rosewill Capstone 550w for that system: http://www.newegg.com/Product/Product.aspx?Item=9SIA0722KD7835
$39.99 after MIR.
https://linustechtips.com/topic/344321-psu-help/#findComment-4695792
