Hey everyone, I recently built my own PC, I am 16 and I came across this issue earlier but I chose to ignore it because I didn't really take it seriously.
My CPU cooler (cooler master 212 evo) is vertically mounted and it is parallel to the RAM which is 8 GB (4GB x 2) and 1 stick is in the 1st slot and the other one is in the 2nd slot. The cpu fan is not going all the way down (keep in mind my computer has been set up already) and I was wondering whether if I could take the RAM stick in the 1st slot and move it to the fourth slot (MOBO: MSI 970 Gaming). I just wanted to ask so I knew what I will do is not going to screw anything up as I am a relatively new PC builder.
PC Part Picker: https://pcpartpicker.com/b/hZCypg  ProcessorIntel Core i7 6700k ; MOBO: Gigabyte GA-Z170MX-Gaming 5RAMCorsair Dominator Platinum 16GB 2400 MHz (spray painted the top part red); GPUGTX 1070 - Gigabyte Variant (Custom painted the Cooler and Fans Red); Case: NZXT S340 (Red); PSUCX 750W  (Bronze 80+); SSD: Crucial 256GB (Boot drive and for applications) and Sandisk 480GB Extreme pro SSD and a Samsung T3 1TB External USB-C SSDHDDWD Blue 1TB, Seagate 3TB (Both Run at 7200RPM); Displays: Asus something (1080p @ 144hz) and LG 27UD68-W 4K 60Hz IPSLaptop: Dell XPS 15 9550 (i7 6700HQ, 16GB RAM, 256 SSD, GTX 960M)
https://linustechtips.com/topic/344102-cpu-cooler-into-ram-issue/
Umm... You should place the stick in either 1st and 3rd slot or 2nd and 4th slot so they work in dual channel mode. Otherwise theyre working in single channel mode. Its actually advised that you move the stick from the first slot and put it into the 4th one.
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
K thanks...
