 The colors on CS:GO now are off and appear orange. I am running windows 10 build 10041
i7-5930K@4.7Ghz | Asus X99-E-WS/USB 3.1 | Corsair Vengance 32GB DDR4@2666Mhz | Duo Gigabyte GTX 1080 Xtreme Gaming | Samsung 950Pro 512GB | LSI 9260-8i RAID Card | 6x 1TB Samsung 850 Pro (RAID5) | Corsair AX1200i |  Fractal Design Defiine R5 Black | MetaDot DasKeyboard4 Professional | Logitech G900 | Windows 10 Pro 64-bit | Asus PG348Q
https://linustechtips.com/topic/343872-csgo-color-problem/
Well, the first thing I can think of is have you changed anything in the nvidia control panel or had a driver update? And have you checked in game settings? I can't look for a solution ATM, I'm not home, otherwise I could test things myself.
https://linustechtips.com/topic/343872-csgo-color-problem/#findComment-4684488
  • 4 months later...
