I went to go buy a gaming pc off a guy he showed me the specs and he actually went well on the price for it too i made a CLONE of all the parts the Computer has which are shown here ( http://pcpartpicker.com/parts/partlist/) everytime i would turn off the system and boot it up sometimes it wont boot up but then sometimes it will. im not sure what the problem PLEASE SOMEONE HELP!
https://linustechtips.com/topic/343752-why-do-i-get-the-red-cpu-light-help/
try to reseat the cpu, have been working for me :)
CPU: I7 4790K GPU: Manli GTX 980 Mobo: Asus Gryphon z97 RAM: kingston Hyper x fury 16GB 1866mhz PSU: EVGA supernova 750W G2 SSD: Samsung 840 evo 500GB HDD: WD Black 3TB Case: Parvum s2.0 Fans: Noiseblocker E-loop 800rpm Cooling: Custom water cooling
I'm at work and decided to take a little of my time to post of what the problem might be I did update the bios since the motherboard bios was a 2103 version and it had a updated version to 2501 i do know that the version 2101 is a older version than the Cpu do you think that might be the problem?
I do end up getting the "BOOT RED LED" light ONLY when i boot it into the BIOS but i checked that out that it might be a bad Motherboard or CPU but when it boots up it goes away. so i don't know what the problem is :/
Take the cpu out of the motherboard and check the socket for any bent pins, they should all look exactly the same. If there is 1 or 2 bent, you can try to put it back in position with a toothpick or something.. but be very gentle.
For the bios.. get it on the latest.
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
But people tell me it can be alot of things from a bad power supply to the motherboard being bad or the CPU having bent pins  i dont want to remove the cpu in fear of actually benting pins lol but people have told me that its just the BIOS if i update it the problem should stop.
Can you point the light? I just can't see it.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
Is it the one that I circle?
PC Specs
Indonesia
Australia
Beside the writing that says MemOK? .. re-seat your memory and try a memory check if yes.
Checking the socket is easy.. it's 4 screws for the cooler, then just lift the lever and the cpu... the pins are on the board these days.. used to be on the cpu. :D
so you system is powered up but the temps is way too low and so is the fan speed
is that when it idle?
use speedfan to verify
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Its an AM3+, the pins are on the CPU.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
Oops, sry, must learn to look at the board..
To the OP, when sharing a build from pcpartpicker, Don't use the link in your address bar, use the "permalink" just below "current part list" on the left side.. The link (/parts/partlist) takes me to MY current or last build (yay cookies)
Oops, sry, must learn to read.. :)
Is all good. :P
