Hi I have just built a new custom pc (first pc for 10 years as ive been using laptops) and for the first time gone over to water cooling. As a stepping stone to a full on water cooled rig I have gone with the Corsair h100.
I ran a stress test on the pc when built and I saw the CPU temperature climb to 83c (181F) When idling and under normal use it only gets to around 30c.
Spec:
Motherboard : Asus MAximus vii Ranger
CPU: i7 4970k clocked to 4.6ghz
Any ideas what the problem is? Is this normal? My friend has an i7 and his doesnt get above 35c
https://linustechtips.com/topic/343130-cpu-running-hot/
Thanks for the reply. I bought the motherboard, cpu, ram and cooler as a pre overclocked bundle so I didnt actual seat it. I also dont know what they did with the overclocking. This was a free service they offered so i thought i'd take advantage. Also meant they did a 24 hour stress test for me. Maybe I should take it off and reseat it and dial the overclocking down a bit. Will it do the CPu any harm running at that temperature?
https://linustechtips.com/topic/343130-cpu-running-hot/#findComment-4674347
open the bios and tell us the voltage its running at (in the overclocking tweaker) sounds like a shitty OC
https://linustechtips.com/topic/343130-cpu-running-hot/#findComment-4674381
@up
Agree with that. They could have just set the voltage to maximum for a sloppy OC. If the voltage is at 1.4 that could be an accurate voltage but it's too high.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/343130-cpu-running-hot/#findComment-4674384
Thanks for the replys today. Thought id let you know that I think it is all down to the overclocking. I set it back to standard and it now doesn't go much above 60c in a stress test.
60c load temps at stock clocks?
CPU Intel i7 8700k | Motherboard ASUS Z370-E | RAM Corsair Vengeance 16GB(8x 2GB) | GPU Asus Strix 1080ti | Case Corsair 570X | Storage Samsung 960 NVME M.2, Intel 530 240GB ssd, WD Caviar Black 1TB | PSU Corsair AX1200iCooling XSPC Photon 270 reservoir, D5 pump, Raystorm cpu block, and an EX360 rad | Keyboard Corsair k70 rgb | MousLogitech Proteus Spectrum rgb
https://linustechtips.com/topic/343130-cpu-running-hot/#findComment-4679309
For this type of questions it would be very useful for you to give room temps since it is directly related to your components temps
https://linustechtips.com/topic/343130-cpu-running-hot/#findComment-4680714
Spec:
What are you using to stress the newer versions of prime are bad 26.6 is the last version that should be used on this platform
http://windows-downloads-center.blogspot.com/2011/04/prime95-266.html
https://linustechtips.com/topic/343130-cpu-running-hot/#findComment-4680866
What are you using to stress the newer versions of prime are bad, 27.9 is the last version that should be used on this platform
fixed
Yeah, we're all just a bunch of idiots experiencing nothing more than the placebo effect.
https://linustechtips.com/topic/343130-cpu-running-hot/#findComment-4681567
Actually I was using the Intel Burn Test application. Would you recommend this one as a better one to use?
https://linustechtips.com/topic/343130-cpu-running-hot/#findComment-4682807
