first gpu installation help
Solved by wyattzx,
When the card arrives, here's what you'll do.
- Download the latest NVIDIA drivers from the NVIDIA website.
- Uninstall your current AMD Drivers for your card. Make sure they're gone entirely. (You can use something like DriverSweeper, but I didn't.)
- Power down your PC, and remove your current Radeon 6670.
- Insert your new GTX 960 n to the same PCI-E slot. (I'm assuming you used your 16x slot?)
- Plug in the required power adapters, as well as screw in the card to the PCI bracket.
- Power on your PC and run the NVIDIA Driver setup.
- Restart your PC after the installation, and you're good to go.
As for selling the 6670? It's a very weak card, so I wouldn't imagine you can get much for it. I wouldn't bother. Just hold onto it for emergencies.
