Are my CPU temps acting up?
Solved by Raudi_,
Yes I know higher voltage and clock speeds cause higher temps but I've lost 10degrees C from changing the motherboard and I dont know if my temperatures are correct or not because I'm only using air cooling.
I've had my PSU for about a good 3years.
That can happen, I dropped temps when I switched mobo's because I needed less voltage. The are correct though if your seeing it throttle at all, it will be due to VRM's overheating.
Hmm it doesn't seem to be 80+ rated plus I can't seem to find the OEM for it. I would just look into replacing it, you can get a pretty nice 80+ Bronze 700W PSU for a good price nowadays.
