A networking question
Go to solution Solved by W-L,
So just buy a different router, run ethernet from modem to router, connect to router instead?
That is correct just be sure to disable the wifi on the modem/router from comcast to lessen inference and since it's not necessary anymore.
Recently my networking capabilities are not up to par.
Before you ask I am the only of a few devices on my network and I have a great wifi chip.
Im cant change router because of Comcast.
So is there any solution of having the modem/router in a different room than my setup besides running a 30ft ethernet cord?
"This is a bad idea"
https://linustechtips.com/topic/342336-a-networking-question/
just saying if you have comcast u can still use a different router, just connect Ethernet out into another router and disable the wifi on it.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/342336-a-networking-question/#findComment-4663855
https://linustechtips.com/topic/342336-a-networking-question/#findComment-4663893
