Swiftech 355 o ring help
Go to solution Solved by W-L,
-SNIP-
i'm not sure about UK stores but I believe performance PC's does ship worldwide:
http://www.performance-pcs.com/bitspower-laing-ddc-series-pump-replacement-o-ring-ddc-series-ddc-12v-alphacool-mcp350-mcp355.html
Well i'm planning on going with a full watercooling loop and need help i've just brought a used XSPC Acrylic Dual 5.25 Reservoir with Two Swiftech MCP355 ( Separate Cpu loop/ Gpu loop)
as it is used i want to flush/clean them thoroughly and change out the o rings but i can't seem to find them online i found ones for the MPC655 which is a D5 pump so i'm sure it won't fit,
any help would be appreciated also a link to where i could purchase one would be great.
i'm from the uk so will need a UK/EU supplier
Motherboard - AsRock Z87 EXTREME4 CPU - Intel core i7 4770k Oc 4.4ghz GPU - Sapphire R9 290 Tri-x RAM - Corsair LP Vengange 8Gb CPU Cooler - Swiftech H220 PSU - Coolmaster V650S SSD - Samsung 840 EVO 250gb HDD - Seagate Barracuda 2Tb Case - Fractal Design R4 Black Windowed
https://linustechtips.com/topic/342296-swiftech-355-o-ring-help/
https://linustechtips.com/topic/342296-swiftech-355-o-ring-help/#findComment-4663287
Cheers i just realised its the same as a laing DDC and just searched around and found a uk supplier http://www.aquatuning.co.uk/water-cooling/accessories/standard-parts/o-ring/9944/o-ring-48-x-2-5mm-laing-ddc-pump
https://linustechtips.com/topic/342296-swiftech-355-o-ring-help/#findComment-4663303
Ah yeah Aqua-tuning should have the stuff you need.  :)
https://linustechtips.com/topic/342296-swiftech-355-o-ring-help/#findComment-4663317
