Im new at all this so i figured i would come over here and ask. im planning a build and have a question concerning RAM compatibility. Im looking at getting an i7 4790k which says it only supports 1333MHz and 1600MHz RAM. But my mother board (Gigabytes Gaming 7) supports much more than that. Can i only use RAM that matches the CPU?
https://linustechtips.com/topic/342279-rsm-compatibility-help/
Disregard the CPU support. You go with the motherboard.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/342279-rsm-compatibility-help/#findComment-4662925
That speed is the Intel specification of the chipset. Your CPU will communicate with the memory bus at those speeds, If you put faster RAM in your system you will essentially be running an 'overclock' on the chipset that could cause instability but its highly unlikely.
Quack 🦆
https://linustechtips.com/topic/342279-rsm-compatibility-help/#findComment-4662945
