hey guys, im planning to build my first gaming computer and i'm slightly confused on the CPU cooler. I'd like to get a corsair h100i or a Cooler master Hyper 212 Evo but i dont know if they are compatible with my mobo/case and if i get one of them will i need thermal paste.
thanks and here are the rest of the specs.
http://uk.pcpartpicker.com/p/j9cwZL
https://linustechtips.com/topic/342244-help-with-cpu-cooler/
Both come with thermal paste, and I think both are compatible with your case.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/342244-help-with-cpu-cooler/#findComment-4662407
You will not need thermal paste for either of them as long as when you take it out of the box you dont accidentaly touch or let anything touch the preapplied thermal paste.
CPU cooler dont matter much if you dont overclock, and the H100i (little old now, you might want the H100i GTX instead) is better than the 212 (given it different in price, it better be). Both with fit your case just fine. So depend on what you do, choose what you need.
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/342244-help-with-cpu-cooler/#findComment-4662434
