DS Aerocool MATX Case - Orange
Asus M5A78L Motherboard - VRM Heatsinks installed
Am3+ FX8350 4Ghz 8 Core CPU
**Watercooled cooling Coolmaster**
Kingston 8GB DDR3 Ram (2*4GB) 2 spare slots!
1TB Sata HDD
Antec Spot cooler - used to ensure motherboard temps kept low
NZXT White LED Light runner
700W PSU Corsair Silver
VS
Intel i5 3450 Ivybridge Quad core CPU (3.1GHz - 3.5GHz turbo)
GIGABYTE GA-Z77-DS3H Intel Z77 Socket 1155 DDR3 PCI-Express Motherboard
Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
OCZ Agility 3 120GB 2.5" SATA-III Solid State Hard Drive
430W Corsair Builder Series 430CX V2 80PLUS Power Supply
Zalman Z11 Plus Black Midi Tower Windowed Chassis w/ USB3.0 NO LED LIGHTS
https://linustechtips.com/topic/342016-system-a-or-b/
Assuming this isnt a gaming build since No GPU is listed for either. I would say System B because the intel 3450 will be faster than the FX-8350 for most workloads
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/342016-system-a-or-b/#findComment-4659556
Neither... They're both poorly thought through and implemented.
That being said, if you HAVE to choose one I would take the second one I guess. It's the least horrible of the two.
The reason I'm taking the second one is because of the MB that comes with the 8350. If it was at least a decent overclocking MB, I would be changing my suggestion to the 8350 build. Keep in mind that the second build isn't a speed machine by stretch of the imagination.
What kind of gpu are you planning to buy?? I would be careful with that 430W "builder" series PSU with the second build. Also, do you need storage? I noticed that the second one only has a 120gb SSD? That's not going to fit many projects.
https://linustechtips.com/topic/342016-system-a-or-b/#findComment-4660178
