crossfire question (please help)
Solved by JESUSARIUS REX,
You can. 270 can go with 270x. 280 can go with 280x. 290 can go with 290x. AMD has allowed similar cards to Crossfire for a long time.
Edit: I'm pretty sure you can crossfire the 270x with 7870, and a 7970 will CF with a 280x, so ya.
Edit2: The 270 and 280 series are rebranded 7070 series cards. The 290 series is the only new GPU. I'm guessing the 380x will be a 290x rebranded.
Edit3: Important note: The 280 will hold back the 280x some. The 280 has 1792 stream processors and the 280x has 2048.
